Perform this procedure to display configuration information for Endpoint Tracking.
Perform this procedure to display global, interface and binding information for Endpoint Tracking.
The following example displays all of the Endpoint Tracking configuration information for a switch.
Switch:1>show endpoint-tracking
Endpoint Tracking Configuration
endpoint tracking status : ENABLED
auto-isid-offset value : 15990000
auto-isid-offset enabled : ENABLED
visibility-mode status : ENABLED
Switch:1>show endpoint-tracking interfaces
Endpoint Tracking Interfaces
PORT
NUM INDEX STATUS
1/1 192 Enabled
1/10 201 Enabled
MLT-2 6145 Enabled
MLT-5 6148 Disabled
4 out of 4 Total Num of Endpoint Tracking interfaces displayed
Switch:1>show endpoint-tracking bindings summary
Endpoint Tracking Bindings
PORT/MLT INDEX TOTAL ACCEPTED REJECTED PENDING TIMEOUT SERVER-UNREACHABLE
1/10 201 5 5 0 0 0 0
PORT/MLT INDEX MAC STATUS VLAN ID ISID SOURCE TIMEOUT TIME REMAINING
1/10 201 00:00:00:00:1b:01 accept 27 15990027 autoconfig 0 day(s), 00:01:40 0 day(s), 00:00:00
1/10 201 00:00:00:00:1b:02 accept 27 15990027 autoconfig 0 day(s), 00:01:40 0 day(s), 00:00:00
1/10 201 00:00:00:00:1b:03 accept 27 15990027 autoconfig 0 day(s), 00:01:40 0 day(s), 00:00:00
1/10 201 00:00:00:00:1b:04 accept 27 15990027 autoconfig 0 day(s), 00:01:40 0 day(s), 00:00:00
1/10 201 00:00:00:00:1b:05 accept 27 15990027 autoconfig 0 day(s), 00:01:40 0 day(s), 00:00:00
5 out of 5 Total Num of Endpoint Tracking bindings displayed.
The following table defines parameters for the show endpoint-tracking bindings command.
Variable |
Value |
gigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
MLT <1-512> |
Specifies the MLT ID. |
summary |
Provides a summary of the total number and status of bindings for all interfaces. |
